Masterbcobb
Connected 270 Crusader engine to hot water heater. On the engine I used standard galvanize plumming fittings. Now I see Crusader Manual says to only use brass fittings. Why?
I agree with the others. Even if this is a Closed Cooling system, you may still see a bit of rust between the steel fittings and cast iron parts.Connected 270 Crusader engine to hot water heater. On the engine I used standard galvanize plumming fittings. Now I see Crusader Manual says to only use brass fittings. Why?
You say "coolant". Is this coolant as in Ethylene Glycol, or as in sea water coolant????Thanks for the answer. I would never use pvc. And as the same coolent runs through the cast iron engine block I would not think rust would be an issue.
