Yup the kit is a diaphragm and two check valves.are there rebuild kits available for the originals? Its the screw together type.
will
Not sure what your engine is but I tossed that double diaphram pump and when to the part store and got an airtex sealed pump with fuel return barb $30
Jeff, I'd be willing to make you a gentleman's bet that the dimple is the lever arm pivot pin location. Yes/No????See that dimple in the casting, just above the shadow brand name? Drill that hole out, press and epoxy a tube end in there, and hook a hose to it. Presto! A marine pump.
but then where is the lever arm pivot point?
Are you suggesting that a pre '76 vessel is not required to be equipped with a Marine approved replacement fuel pump today?Not the issue with pre 1976 boats!
I did fine this:
FUEL PUMP KIT CHRYSLER-4" LM318/360![]()
$222.49
CHY1736073-K4
Used to replace original design fuel pump used 1968-1975 LM318 and LM360 which had no vent tube from fuel pump to flame arrestor.
This kit supplies a new fuel pump, new flame arrestor (for 4" throat carburetor), and approximately 3' of tygon (semi-transparent)vent hose.
Supplied with mounting gasket.
Carter locates the port for the diaphram burst protection line as shown here.
Carter M6766 or Sierra # 18-7254
Jeff, you may be correct re; the dimple. Here's a pump for the OHC Volvo Penta.
Looks like the vent is in a similar location as with the Chrysler automotive fuel pump "dimple".
Electric pumps have their own problems!
Jeff
