"As luck would have it my port
"As luck would have it my port side gear is showing a small leak at what appears to be the rear seal just ahead of the shaft coupler. No spraying of ATF to speak of but new oil absorber pads reveal a consistent but small amount of ATF below the coupler area only after each run.
I beleive they are the 71C (model 10-17) velvet drive gears connected to 1984 454's. Either that or 72C gears but 71C sounds right. Looking for a new seal Borg Warner part # 71C-110 comes up. Can anyone confirm this?
Anyone replaced a rear seal in one of these older in line gears lately? It looks like you remove the coupler nut and coupler and the seal is right behind it. Looks like a good rainy day project if I had the right seal in hand.
Regards,"
Regards,"
