Well took my boat out 1985 140
Well took my boat out 1985 140 hp mercruiser out yesterday for my test after the water pump and the upper and lower reseal was done and it ran fine.So today i deceided i was going to take my family out and the boat also ran fine.Stopped off at a beach did a little swimming and went to back up to go int the channel again had lower unit up where it was suppossed to be and it didint seem to have alot of back up power so i backed up ever so slowely and went forward and gave her the berries and a weird knocking sound started coming from my lower unit and the boat started vibrating really bad what would cause this.When i trailerd the boat i noticed in forward gear the prop spins one way and doesnt the other but in reverse gear with just a small amount of pressure it will turn both ways in neutral it spins freely like it is suppossed to could this cause my noise and vibration from something shot in the lower unit does it sound like a big fix i just had it in for 384 dollers worth of work.Does a i/o have a shear pin or something.
