joe cool 565
91 glastrom volvo penta 230 boat works great for a while then it will rev up acts like a clutch slipping in a car just recently got boat i changed lower unit oil i have no manual but info i found said it uses same oil as engine 10 30 so i used delo 15 40 also found when working on it was end play in prop so i tightened prop is there supposed to be endplay in prop or is it a torque spec and what is it the oil i drained smelled like gear oil is there a clutching system in the lower unit do i need gear oil in it what could cause it to slip any help would be much appreciated
