The boat is big. It doesnt jump out of the hole.
You'll want to install a Duo Prop lower unit!
It will change the characteristics of your boat tremendously!
It has a Panther 350 engine thats getting tired and cruises at 20-23mph.
There is an alternate build that you can do with the SBC....... don't settle for the GM version!
Even at that speed I cant let go of the wheel. I tried to adjust the tab on our last outing but I went the wrong way. In reading I will adjust it towards the way it pulls. The out drive is not the power trim model its up or down. I noticed that the scag on the bottom is flat from dragging the ground or being left down when pulling it out of the water. Its not rounded like some of the others Ive seen. Not sure if that has anything to do with it or not.
With the skeg being worn down, it would explain part of your steer torque that you were feeling!
