"I know this is not an engine
"I know this is not an engine question, but you guys have such a vast wealth of knowledge. Should the drain plugs on the bottom of the boat be screwed in from the outside so that the wrench flats are on the outside of the hull or screwed in from inside the hull. I have seen them done both ways and I don’t know which is correct. I have always screwed them in from outside the hull for no reason other than that is the way they were when I got the boat. Doesn’t mean that it was correct. Does it make a difference?
Thanks for your help."
