Since it's near the end of the boating season here at lake Tahoe, I thought I would post an update on an earlier post regarding engine trouble with my 1986 Bayliner with AQ131A/275. In early June, after a nice 30 minute run to one of our favorite coves, the engine suddenly quit. We got a tow from TowBoat US back to our launch site. I strongly recommend the Boat US towing insurance service wherever it's available - it provided a free tow service for a normally $500+ tow.
Inspection with a boroscope in cylinder #4 revealed a near-complete disintegration of #4 exhaust valve crown and significant damage to the piston head.
When I originally posted about this problem here, the prevailing educated opinion was "it's a major rebuild - probably not worth it considering the age of the engine/boat." In any event, +$$$ ahead for a repair. I pretty much agreed and initially decided to sell it as a project boat. To make a long story short, I eventually decided to do a minimal repair to the cylinder head, do nothing to the piston other than grinding way any impact-induced projections, and see what happens. I did the following:
To my delight, the engine fired up after a prime and ran as smooth as ever. (!!) Here's a pic from the first day's "sea trial."
To date, we've have about 25 hours on the repaired engine and it continues to run well: no oil usage, no water or exhaust in the oil, fresh water clear and clean. Will the "good luck" last?? Time will tell. On a "cost versus benefit" basis though, I'm currently ahead. I added up the repair parts /fluids cost recently: $250.
I would never have attempted this repair if I hadn't gained tremendous knowledge and insights from the posters here. Thanks to you all for a great service!
- Replaced exhaust valve #4
- hand-lapped all the valves that showed leakage during a water-retention test.
- Since the cylinder walls of #4 were not visibly damaged, I simply cleaned and deburred the piston crown.
