flabob1
Ok new problem now.
I just installed a Hummingbird Helix 7 unit. Wired it to my main bus. When I turn on my other GPS Unit the Helix goes dim nd erratic.
I was told that interference from other unit is causing it. Was told to wire it by itself.
So I wired it directly to the engine battery switch and ground. using the correct gage wire.
Now if with the Helix on and start the engine it blows the fuse .I had a 3amp fuse and also use da 5amp fuse ( didn't have another 3amp) and it blows .
How or why is voltage going to and blowing the fuse when I start the engine.
Help Please ;
Bob
Help Please ;
Bob
