"I have ovehauled and rebored
"I have ovehauled and rebored a evinrude 1987 70 hp. At first startup i notice that the engine runs a bit rough on idle. After searching through som posts here i figured I might not have cleaned out the carbs enough so i disassembled them and cleaned the thouroughly. Next startup same rough idle. I now notice blowback throug the top carb. This was probably the case at first startup as well. So off with the carbs and checked the reeds. reeds look fine but I see a small hole in the reed plate that matches a hole in the crank cover, like some sort of ventilation or recirculation. I think the blowback is through this hole/path. There is a matching hole in the gasket (aftermarket from GLM) but I'm unsure that this hole in the gasket was in the old one I removed (and threw away, off course).
Is it safe to plug this hole and try the engine again?
Why would there be ventilation/recirculation on the top cylinder?
The hole/path is similar to the one in the lower cylinder crankcase that leads to the air silencer but this one has larger hole and ends right outside reeds (not in a nipple or such)."
