"Recently purchased a 1997 boa
"Recently purchased a 1997 boat with 350 V8 and realized today that I have a weeping block leak about 2" above the block drain on right side. There is a rust stain down over block. You can dry it off and immediately you see a drop of water appear and start to run down the block. Also, on the left side there is a stain in the same spot that appears like it leaked but it is currently not wet. I know this boat has been fresh water used for the last four years but before that I'm not sure. Any thoughts on this issue or what I should do with it would be appreciated. Thanks"
