"To my experience the best way
"To my experience the best way was to tilt the unit fully up and support the lower unit. That way You get all oil under the cylinder pistons. Then completely remove the release valve and slowly lover the unit manually. This will if done correctly push out the highest volume of oil. Then manually lift up the unit again and support it. Put back the valve, but leave it one turn open. Fill as much as possible in the reservoir and run the pump to bleed out air. Tighten the valve, fill and run pump until unit 'lifts' from support. Lower and raise a couple of times and check/refill oil."
