Big problem
G
geoff burden
Guest
i have a 100hp comm johnson wi
i have a 100hp comm johnson with no spark. the model # stamped on the block is 100193c and the serial # is e01822. the problem is everyone i talk to say that that model # never existed will someone please tell me what is going on here.
Stop talking to " everyone
Stop talking to " everyone " that motor is a 71 and you can find it right here under MANUALS / then EVINRUDE MODELS then 100 HP
"Just a genaral question,not a
"Just a genaral question,not a beef,should visitors conduct them selves in this manner, sounds more like a dog fight,than a solution fourm, that is only my opinion. TKS MJCormier"
does anyone know what the volt
does anyone know what the voltage from the amplifier is supossed to be?
"Geoff.... Hopefully the follo
"Geoff.... Hopefully the following may be of some help to you.
(Voltage Drop To Battery Capacitance Discharge)
( Pulsepack When Electric Starter Is Engaged)
(J. Reeves)
On the older Battery Capacitance Discharge ignition systems (1968-1972), the electric starter reaches a point, even with a top notch battery, whereas the starter will draw excess voltage/current/whatever which results in a voltage drop to the pulsepack. The cure is to purchase a diode which is capable of handling 12 volts and installing it between the starter terminal of the starter solenoid (NOT the battery cable terminal) and the wiring terminal that supplies voltage to the pulsepack.
The diode must be installed so that the current flows from the starter terminal of the solenoid to the pulsepack... NOT vice versa. When that diode is installed in this manner, when the key is turned to the start position, the voltage that is applied to the starter is also applied directly to the pulsepack via the diode effectively eliminating the voltage drop and energizing the pulsepack with the required voltage needed for its proper operation.
(Battery Capacitance Dischage Powerpack Test)
Various OMC Engines - 1968 to 1972)
(J. Reeves)
Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. You might use a bulb of a somewhat lower voltage to obtain a brighter glow... just a suggestion.
Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire).
Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed.
Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
When time permits, visit my store (copy/paste) at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
To another party: LM/AB/MG/IK Isn't it time you registered?"
ok so i have 12v going to the
ok so i have 12v going to the amplifier and 59v coming from the amp to the coil but when the coil is grounded as it should be all voltage drops. i used a continuity tester on the coil and found that there is continutiy between the terminal that is hooked to the amp and the ground blades on the coil. i thought that the coil was bad so i purchased a new one and the new coil is the same way.
i have a 40hp johnson i have n
i have a 40hp johnson i have no idea what year it is can someone please help me the model is rdsl-250 serial number is c386728 thanks
