Yes, no impeller in a Bravo. If it's a Merc, you have an Alpha drive. If you suspect there are shutter parts missing and still in the exhaust, remove the drive and look through the exhaust bellows and into the cavity of the transom assembly as well as the exhaust section at the front of the drive when you pull it off; two likely places where shutter parts may end up as well as the exhaust passage inside the drive that is accessable when drive halves are apart. The older shutters were a single SS plate with a rubber/plastic edge and a shaft, the newer/replacements are dual plastic/rubber flaps, some have a plastic collar as well. The shutters are there to assist in preventing water from making it's way up the exhaust and into your engine due to swells, reversing, launching down ramp etc. You need to install new ones.
