Alan,
Thank you so much for getting back to me. I have now got the shift shaft cam back into the slot. I buttoned it up filled it with gear oil and put the upper portion of the engine in neutral and then used the shift shaft on the lower unit to put it into neutral. Now I have forward movement in Forward, Neutral and Reverse!!
I have checked the problem motor over with the adjacent bf90a(twin engine cat). The upper portion; cables, detent and upper shift shaft all coincide with the adjacent motor. Any advice or help is again greatly appreciated on getting the lower unit back in sync with the rest of the motor.
