It runs awesome at high RPM, IE 3500 RPM and above. At idle, it runs fantastic, until it runs out of fuel, then it starts to stumble.
If I start pumping the fuel bulb right when it begins stumbling at idle, the stumble goes away and it idles fantastic. Fuel bulb is soft after idling for a while. Getting the engine back up to speed, no more soft fuel bulb, and no more stumbling.
Ran the engine WOT for at least 1 hour and 20 minutes with no problems. Burned almost 5 gallons of fuel. Run it at idle for 3 minutes, engine stumbles and will stall.
https://www.youtube.com/watch?v=G5ESbKiFi_E
Fuel pumps are about $150 so I'm going to gamble on them, but just want to check if it could be something else I'm missing. I don't think there are any vacuum leaks in the lines.
