RedRattler
I have a BF90 on my pontoon with power trim and tilt/remote control. My BF90 gives the solid buzz and automatic throttle reduction that indicates I have an overheating or oil pressure problem. This happens as soon as I turn over the engine. I revved the motor in neutral, reverse or forward but received the same buzz. The weird thing is that I only get the alarm when the boat is in the water. If the boat is on muffs or a bucket, the alarm does not sound.
So far, I have:
1) replaced the impeller and surrounding seals.
2) replaced gear oil in lower unit
3) verified engine oil is near the top end of mark on dipstick
4) unplugging the Red and Yellow wires connection between sensors and CDI unit to disable both sensors
5) verified with an infrared thermometer that the temp of the engine is fine (still cold)
6) let the engine run at idle in the water for 5 minutes with no buzz
Nothing has worked so far. As soon as I try to rev the engine, the buzz returned.
I can stop the alarm from buzzing if I push the tilt down, but the alarm starts back up as soon as I release the lever.
I ordered a new thermostat, which should arrive today, but I can't see it being a temperature issue if the sensor is disabled. I also plan on taking my ohmmeter to test the CDI resistance per the service manual specs.
Is there anything else I am missing, which might cause the solid buzz when in the water above idle? I am hoping I do not have to replace the CDI, but will if the resistance test fails.
Thanks in advance for your help.
So far, I have:
