Hello this is my first post. I have a 1999 bf90 I have owned for about 2 years. Now this may just be normal of the carburated motors but not with the ones I have owned in the past. So first off on cold start it usually starts right away with the fast idle in choke position. But then I have to wedge something like a pen to hold the fast idle half way up for about 3-5 min until its its warmed up enough to put in normal position. If taken out of fast idle before warm it will just bog down and die. Once warm its good to go all day and will usually start first turn without choke. Seems to me the motor should have a function that automatically chokes the motor until its warmed. Last night I pulled the carbs and carefully clean all the jets thoroughly.to my surprise they were very clean. When restarting it didn't really seem to make a difference. I had also synced the carbs too. When its at idle it almost sounds like it has bigger cams. I guess I just picture a Honda motor being very quiet and smooth....like how the fuel injected motors run. On a side note, running a factory 17p aluminum prop I'm only maxing at 5200 rpm.
Any help would be greatly appreciated. Thanks
Ryan
Ryan
