Hello Mike & johnny, thank you for the information ! i got the motor started yesterday & let it run for two hours at idle,throttling it up in gear occasionally, while docked, & it quit once after warm when throttled up but restarted when choked but then didn't want to idle down without quitting. i shut it off & pulled out the brand new plugs (ngk dr5hs gapped @.026 & they were black & dry,i would post a pic of them but don't know how to do that yet,sorry. I haven't tried to re set the idle mixture screw yet because i'm not sure of the meaning of the word "turn". does it mean to count the # of 180 degree turns or is each turn a complete 360 ? my next trip to the boat i'll clean & re gap the plugs & set the idle mixture @ 1 3/4"turns?" out while the motor is cold, then start it up & keep it running until it warms up & then adjust it in or out 1/4 turn at a time & see what it does. then if it still doesn't want to idle right i'll try adjusting the idle speed in or out in 1/4 turns.I know where the #10 screw is & have sprayed carb cleaner in it & blew it out with compressed air but i can do it again. in regards to the question about familiarity with the motor, i have had it for 5 years & it only has approx 40 hours on it since it was completely rebuilt from the ground up by the po who was a very qualified boat mechanic. the motor has always been dependable for me except i've always had to start it with the choke pulled all the way out,whether the motor was cold or warm. what would be the cause of that? i purchased the boat in california & brought it here to puerto vallarta & thought that it might be issues with the gasoline they have down here. thanks again & if i don't hear back from you about the" turn" terminology i'll figure it out & i'll post my results. thanks again guys ! by the way, honda outboards are very rare down here so it's hard to find a qualified mechanic that knows about hondas. I think 4 & 5/8 turns (i'm counting 1 turn as 180 degrees) as extreme & am hoping this is the problem
