Hello,
1st time here, and this is my 1st Honda outboard, and 1st 4 stroke.
BF8A
BZBC 1400107
It has been running fine then last weekend it was hard to start, and when I did get it running, I had to play with the choke to keep it running, at lower throttle settings. I assumed that the idle/low speed jets are clogged.
I disassembled the carb and sprayed it down with cleaner. I sprayed through on e hole and could see cleaner coming out of the jets.
Put it back together, and when I tried to run it, nothing really changed. I still had to jockey the choke. I pulled the fuel line off the carb inlet, and used the bulb to force fuel through the pump and hoses into a bucket. Put it all back, and it seems to run ok now, but at idle it's still lean, as it will speed up when I pull the choke out about halfway.
1. glass inline filter looks real clean.
2. no leaks in hose or connections when I squeeze the bulb.
3. fuel spits out if I pull the line off the carb inlet and pull the starting rope.
4. just cheap 87 octane fuel with nothing added to it.
The filter always seems to have fuel in it but usually has air too. I read several other posts here and they refer to removing an idle screw for cleaning, but mine doesn't have one. Maybe I just didn't get it clean enough?
Is there a better way to test my fuel pump?
Thanks,
JIm
BF8A
BZBC 1400107
Thanks,
JIm
