Got an older carb'd BF75 that I brought back to life that is a bit cold blooded. Symptoms are when first put in the water it starts best by having the throttle up a bit and then you have to leave choke on for a few minutes. Run's great once warmed up. If out fishing and shut the motor off, if it sits for any time at all one has to hold the choke on for a short period or it doesn't want to stay running until you bring the RPM up a bit. The water temps where I am at is typically in the 60's.
I have pulled and cleaned the carbs. Obviously can't pull out the mixture screws without breaking them so the cleaning on these was spraying carb cleaner through all the ports. I did pull out everything possible and cleaned thoroughly. The carbs were surprising clean. I did not sync the carbs but looking at the adjustments, from the factory, the paint marks are all still in line and doesn't appear to ever have been adjusted. A dealer told me that he has found with the Honda carbs that they about need to be cleaned in an ultrasonic cleaner as even though all looks well you just can't get everything cleaned off. Also said to check Sync. Not sure I buy into this. I have turned wrenches all of my life and never had a problem with not being able to clean carbs with elbow grease but admittedly my experience with outboards has been limited to the BF50A and this 75. I suppose the idle mixture screws could be a problem but I don't think you can get them out without breaking them at least according to the manual.
Also made sure valves were set correctly.
Any thoughts on this? Is it possibly just the nature? I can by a sync manometer but I hate the thought of spending $100 for 1 use in several years. Also the engine runs well other than when cold so not convinced syncing would help.
