Hi guys,
I have a 2005 Honda BF50A and had some problems this summer with trim/tilt switch. First the battery died but it was very old and it was high time to change it anyway (I guess the switch already started shorting and that finished it off). When I installed the new battery using remote control trim switch started blowing fuses (I think it was the 15 amp one) and after I changed a couple while testing this, it even started smoking a bit around the engine connector bracket (on the side of the engine below the black perforated plastic cover). As all this was happening just when I started my vacation
I removed the cover and figured out how to disconnect the remote switch and rewire it so only the switch on the engine could be used. I asked around and they told me it could be either the switch or in worse case the wiring harness which can only be completely replaced and is very expensive, business as usual
I tested the switch and it seemed fine, in the end I left it disconnected like that and only used the switch on the engine.
Recently I had to disassemble everything on the boat anyway so I figured I'd check this out, brought the remote control and the wiring harness (the cable from the engine with 3 connectors on controls side and a big round one on engine side) home and tested it with an ohmmeter. First I checked the 3 wires from the switch (Lb, Lg and W/Bl on the wiring schema) on the controls connector and there are no short circuits between these 3 and any other pin on the connectors. When switch is pressed it connects W/Bl to Lg (up) or Lb (down) as specified on the schema. Then I checked the cable and again couldn't find any short circuits between one of these 3 wires and any others. Any ideas what the problem could be and what else should I check ?
Thanks in advance.
Thanks in advance.
