Stillwater
I have a 2004 BF50. It has a clicking/ticking noise which sounds like rocker arms. It is a constant clicking at camshaft speed.
Here's what I've done so far with no success. It is noisey enough I won't run it until I find the answer
-I have adjusted the valves (twice) to min spec .005 in. and .008 ex and the noise is still there.
-adjusted the camshaft belt
-The noise is in sequence to the valve train speed of 1/2 the flywheel speed.
-With a stethscope the noise is seems lower on the head and when put on the fuel pump it is very loud.
-I run the boat in the lake today to put it under load, but no change.
-At idle it's not too bad but audible and an increase in rpm brings a much luder noise Easily heard from steering wheel with cowling on
-throttle up in the lake from standstill to WOT is normal.
Two guesses on my part---
Has anyone experienced a fuel pump failure like this where the tension on the fuel pump plunger is weak and it makes a noise???
Has anyone experienced a "floating" rocker arm that slides a few thou on the shaft and snaps back against the spacer/spring assembly
I don't see evidence of a any wear/misalignment from a floating rocker arm.
Or am I missing something completely??
(sorry for the long post but more info is better than not enough I guess)
