Hi peeps.
Doing a service on the boat and also changing gauges to NMEA.
I have the backbone installed and powers. Have a Garmin 75 and KUS NMEA gauge that can see each other on the network, so I think I can rule out a setup issue.
However, the engine won't register on the network. I've check the cable continuity and it's good. Engine starts and runs great, just not showing up on the network and I'm stumped.
The image below shows an unconnected plug (indicator wire), this is not connected to anything as I don't have this cable. Is this the issue?
I've swapped backbone "T" plugs, removed network items to a minimum, but the engine just won't show up!!!
