Looking for some help with an intermittent check engine light on a 2013 Honda BF40D (approx. 500 hrs).
Background:
Symptoms:
Recent developments:
Background:
- Engine has always run extremely well.
- Starts easily, idles smoothly, trolls all day and pulls full RPM.
- No loss of power, no limp mode, no stalling.
- Strong tell-tale at all times.
- No overheat light, only the check engine light and buzzer.
- Replaced thermostat.
- Adjusted valve clearances (a few were slightly loose).
- Replaced the high-pressure fuel filter.
- Attempted to reduce idle speed by adjusting the throttle stop.
Symptoms:
- Check engine light comes on intermittently.
- Clears with a key cycle.
- Originally seemed to occur mostly after sustained high RPM operation.
- More recently it can occur after long periods of trolling/idle as well.
- Engine continues to run normally when the alarm is active.
- 3 long flashes followed by 4 short flashes.
- No pause between them.
- Repeats continuously.
- I've noticed the engine may be taking slightly longer to start than it used to (hard to quantify, but perhaps an extra 3-5 seconds of cranking occasionally).
- One warm restart after sitting for 10-15 minutes required a couple of attempts and coughed before starting.
- Once running it was completely normal.
- On the flush muffs at approximately 3000 RPM I observed the engine hunting up and down by about 250 RPM continuously. This was new behaviour.
- Occasionally I think I can smell fuel, although I have found no visible leaks.
- Thermostat removed and inspected.
- Cooling system checked.
- MAP sensor removed and inspected (looks like new).
- MAP connector clean.
- 5V reference and ground present at MAP connector.
- Fuel filter housing O-rings have now been replaced.
- All sensor connectors disconnected, inspected and reconnected.
- No visible corrosion anywhere.
- Engine oil level and condition normal.
- MAP sensor / MAP circuit issue,
- Fuel pressure or fuel delivery issue,
- Crank position sensor issue,
- Or something else entirely.
