"Got a problem with my BF40A,
"Got a problem with my BF40A, it worked well last time I used it (about 12 months ago) but wont start now.
I checked the fuel and it had water in it so I completely drained the tank, flushed it with fresh fuel and changed the underfloor water separating fuel filter completely(the whole unit).
Still wouldnt start...
I changed the in engine fuel filter, checked the plugs and even though they looked ok I repaced them with new ones, tried again to start it, no go.
I drained each of the carb bowls, pumped clean fuel through them with the bulb, tried again, still no start.
I checked the spark by removing a plug lead and putting a screw driver into the lead and grounding it to the motor lift point, couldnt see a spark so in desperation I grabbed hold of the blade of the screwdriver and there is CERTAINLY enough spark to scare my cardioligist!
I havent got a detailed enough manual to risk stripping down the carbs myself but is there anything else I can try before taking it to the Honda stealer and parting with loads of cash?
Thanks in advance,
Ash"
Thanks in advance,
Ash"
