BF250D trim tilt limit.
Heligeorge
Dear Honda Friends,
is there a way to program the newer Honda BF250D to trim up to a specific point and no more?
m
Many thanks.
It has a micro switch with a lever arm that runs on a ramp on a slip collar that is on the tilt tube. 2 screws hold the slip collar on. You need to loosen them slightly, then turn the collar until the limit switch contacts the ramp when the motor is at the desired height. The collar can slide away from the limit switch lever, so check to make sure the lever is on the collar ramp before adjusting.
