Took boat out as soon as i hit 2000rpms the check engine light and buzzer goes off.checcked engine out found both thermostat housings corroded and leaking . Rplaced housings (came off in pieces rinse motor after each use) thermostats and hoses to water jacket.started motor as soon as i give it some throttle same light and buzzer goes off.replaced low pressure filter and cleaned out water seperator found hite float on top off boss so it wont travel up and down is this correct? Now motor wont start at all. What else should i check?
