BLUF: Looking for a guide on installing the mesh fuel filter (#4) on the fuel rail
and the fuel pump filter on top of the VST, behind the injector base (#5)
BACKGROUND
I bought a rough boat with twin BF200A2. The stbd engine works great and the port, not so much. I've replaced all the filters and cleaned under the fuel pump, that helped a lot. The port engine dies whenever I throttle back to neutral. It'll start right back up but a PIA. The engine starts hard and I frequently need to rev the engine above 1k until it warms up enough to run back at idle and even then its a lopey idle. I have two manual and neither describe how to remove either filter so I assume this is some secret Honda knowledge, or its so simple I can't figure it out.
MESH FUEL FILTER
I removed the pressure regulator on my fuel rail couldn't get the mesh filter out. From the manual it looks like the filter fits into the fuel rain and the pressure regulator seats on top. I didn't pull the entire fuel rail off the engine so my access is limited. I don't want to damage the seating area where the pressure regulator sits. Heck I'm not even sure there is a filter in there since the last owner didn't have a LP fuel filter and the HP one was very dirty. Is there a trick that I'm missing or should I try and use a pick to remove it?
FUEL PUMP FILTER
Is there a trick to changing the filter? Since its behind the injector base I don't want to start pulling hoses if it's bolted to something.
Thanks in advance
.BACKGROUND
MESH FUEL FILTER
FUEL PUMP FILTER
Thanks in advance
