Hello All,
I was doing the beginning of the season maintenance and was replacing the spark plugs. The book calls for 13 ft lbs. which is NOT much and when I removed the old ones they could be loosened with basically two fingers on the wrench. I put the new ones in with like 18 or 19 ft lbs. to be a little safe. Nothing worse then having a plug back out. I have an S2000 and this is a known issue that the OEM spec is to low.
So what say the experts....13 ft lbs to low???
