"Having a problem that's d
"Having a problem that's driving my local tech and myself nuts. Have a BF135A. It's an 06 with about 750 hours. Had it since new. It starts and runs fine at running speed. When throttling back to idle speed it will stall. When backing off the beach at 1000 RPM it stalls when dropping back to idle speed. I read the problem the guy was having with the 130 about a month ago because it sounds like same thing. I checked the plugs all slightly burnt but all same color, changed them. Replaced high pressure filter. removed and cleaned IAC unit with brake cleaner and lubed with WD40. Checked RACOR no water in fuel. Tried adjusting idle screw but that doesn't seem to change idle speed (700 RPM). According to service manual should unplug 2 prong plug from IAC to adjust idle. When I do the engine dies. My tech has been trying to contact Honda but they put him on hold forever or don't return his call. He is our local Honda dealer. Any suggestions would be greatly appreciated. Thanks"
