BF130 Overheat
percy
"Hi guys, I have a BF130 which
"Hi guys, I have a BF130 which has been running perfectly for two years. It was second hand when I purchased it but appeared well cared for a serviced. I have recently been getting a warning light, a red one located on the bottom of the side mounted remote and an alarm. I believe this to be an overheat warning however the tell tale is still running ok.
If I switch it off, and restart, it often clears and runs perfectly for the remainder of the day.
Can anyone tell me what the problem might be ?.
Thanks"
Also check that impeller and t
Also check that impeller and the gasket from the impeller housing to the tube. That was the case for me...the gasket was not properly installed after Impeller change...even the liner was installed wrong...Some Honda Mech.....:-(
