Hello to all,
I have been reading through all the threads here trying to find a solution to my problem. There is a wealth of information on here, but I have not been able to diagnose my "no start" with the information in the forums.
I have a boat with a 2002 BF130 which has performed flawlessly up until a few weeks ago. The person I purchased the boat from had to put it in the shop because when we went to test drive it, it was running like crap. Turns out that a dirt dauber had built a nest on the timing belt, causing it to jump. While it was in the shop to replace the timing belts, they replaced the old fuel system with the newer version. I figured with all that work, I would be good for a few years. A few weeks ago, I took it out to meet some folks over at a swimming area. It purred like a kitten, as it always has, on the way out there. I was there for a few hours and when I tried to start the boat, it just turned over, but wouldn't fire. Luckily, someone towed me back to my dock as they were headed that direction anyhow.
This engine has always started as soon as I hit the key. The kill switch has never worked on this boat. I thought that might have been the problem, so I replaced it. When that didn't do the trick, I started searching online for a solution, which is how I found this forum.
I had a local mechanic look at it, and he said it had no spark, but being unfamiliar with Honda engines, he declined to go any further into it. I called another mechanic out to look at it, and he said it had intermittent spark. He replaced both coils, but that did not change anything. He also was unfamiliar with Honda engines and told me I should take it to a Honda shop. As the nearest Honda shop is a 3 hour round trip, I would like to see if I can resolve this myself.
I found the jumper and checked the MIL lights. It is giving me three different codes, 3, 7, and 14. These all appear to be on the intake side. If I am correct, 3 is the MAP, 7 is the Throttle Position Sensor, and 14 is the IAC. I am not aware that any of these would affect the spark.
I got a OHM meter and checked the resistance to the pulser coils. One read 1058 and the other 1062. Those figures appear to be in range. I don't know of a way to test the voltage on the pulsers when the engine is turning as I have heard that will blow most volt meters.
The plugs look good, just soaked with Gasoline. They do not look fouled.
As others have suggested, I went through the wiring harness and checked all of the plugs for corrosion. Everything looked clean. I am now looking for the grounds. I understand that there are several grounds that run to the ECM, but I do know know where they connect to the grounding source. This is where I need help.
Does anyone know where these grounding locations are? From looking at the wiring diagram, I think the 2 grounds for the ignition are the brown/black wires that go to Connector B on the ECM.
If any of you know of any other things I should be looking for, please let me know. I am not all that familiar with outboard engines, but can typically Forrest Gump my way to a solution on automobile engines.
Any help would be appreciated.
