Hi!
I've got mine off the boat, lower unit pulled, transom bracket apart,etc to clean and repaint everything and have couple of questions
The shift shaft water seal, is that replaced from top or bottom? I pulled the cclip and i didn't know what that was under the washer crud or the remains of a gasket. Just wondering if I can replace that from below, I can't quite tell from the repair manual.
Anyone know how to remove the cover handle? I thought it was an allen key in that little hole but it's not, can't seem to find in the repair books anything on removing this.
Don't supposed anyone knows of tip to easily remove the swivel from the mount frame? I don't have a hydraulic press but looks like one will be required for removal/reinsert. Anyway I can take it apart without a press? I can always work the putting together out later. Why honda makes this swivel out of such crap i have no idea...never seen one that didn't look like it was dug out of the ocean from roman times. My df50 is swivel is looking like crap as well. I'm going to pull mine off sand blast it, then epoxy over it with any luck.
