Piratejason
Thanks in advance for any help!
I purchased a BF45 last week - knowing that the PO left some maintenance unattended. Motor runs great on hose at fast idle - strong flow of water out of tell-tale. While on hose if I put motor in gear and throttle up - scale breaks loose and clogs tale tale - I pull the hose off - try running wire to no avail. As a last resort - I pulled the thermostat off and made a seal to garden hose - removed tale-tell nipple - water pressure blows scale out. I have done the above three or four times - last time treating with a small amount of CLR. I am still trying to get motor to come to full throttle without stopping up.
After doing the above I notice the oil was now milky - obviously has water in it. Is this a function of a pressure relief from the water hose or did I break something? Forgot to add - water from tale-tell was ponding in motor housing - could this have leaked in?
I just want to eliminate the obvious before I drop off at dealer-shop.
Thanks for any help. I have two little boys counting on me to get this thing going!
PJ
PJ
