beeconstructive
Hi, after my boat sank I stripped down the outboard (honda bf 35) immediatly to rince and flush with wd.
All was well untill, I removed or started to remove the crank case only to find I could not remove the crank case without removing the lower cowling.
I purchased a shop manual only to find I need to remove the oilpan in order to take the power head of the lower cowling!
I have now removed all of the screws I can find but it really does'nt want to separate. Is it glued to the gasket or are there hidden fixings I havn't found?
The manual just said remove the bolts, any ideas would be greafully recieved....
