BF 225 alarm getting on plane and idles
tarpontown
"My 2007 BF225 starts the temp
"My 2007 BF225 starts the temp alarm when i start getting on plane. I throttle back to neutral and it goes off, then i start throttle in and never comes up again. The techs here replaced the impeller, did not work, then one of the sensors right in the backbone of the motor (opened the whole think), no success. Today, they cleaned the o2 sensor (i could not be there to check it but one of the guys working with me was). They tested for about 10 minutes and the alarm never came up. Whould this be solved just "cleaning" the o2 sensor? I need some time tomorrow to re-test. Anyone has had an issue like this one? Thanks for your help"
It did not work. I tested it t
It did not work. I tested it this morning and had the same alarm. I called a different service and they said "check the thermostats".
Seems like every service center tends to Guess the solution. Can't believe they are recognized by honda. Maybe honda motors do not worth
I opened the thermostats this
I opened the thermostats this morning and one looked bad..... and the rubber ring is broken too. I will try to replace them. But the parts are limited here in mexico for those 225. Where can i buy parts online or ft lauderdale area?
