I have a 295 BW with 2 BF225s. The port engine just started acting up. The lower two port cylinders did not fire. Tested by pulling the connector to the coils. I let it run for a few minutes and it blew the 15 amp fuse. The port center coil was shorted to ground and swollen - hard to remove. Honda said it may be more than the coil. They said to replace the coil and let it run at idle and feel the tempurature by holding hands on the end of the coil, If that position got hotter than the ohter coils the the ECM was Bad. I replaced the ECM and the bad coil and the same two cylinders won't fire. The plugs are like new. I suspect the injectors. But the way all this happened I wonder if there could be another reason. I assume the ECM also controld the injectors. Any help is greatly appreciated. So far the Honda mechanic is puzzeled.
