BF 130 water in the flywheel compartment
E
Eduard Kikas
Guest
I have problem with water/mois
I have problem with water/moisture in the flywheel compartment.
Starter is sealed and water can not come from outside!
Where the problem can be?
Can this damage anything seriously? (except starter)
Thank you for this. Can be as
Thank you for this. Can be as simple as that!
But any ideas where the water comes in the flywheel compartment? From starter mount hole or from somewhere else?
you might want to start motor
you might want to start motor up in water and remove the cowling
might be a thermostat gasket
