Bf 130 oil leak
G
grego Brown
Guest
i have twin bf 130 and both mo
i have twin bf 130 and both motors started leaking oil below the head down on the outside of the lower case to the skeg. What could this be ? Thanks Greg
"I have the same problem, espe
"I have the same problem, especialy when my 2 engins are up, out of the water. Am in the process of repair. In doing some cleaning, under the lower case, I damaged a rubber seal where the shift rod hooks up to. It's not a minor job to chang for you have to dismantel all the lower unit and take out the engine. There may be a short cut to get to it but I have not tried it on my other engin yet.Will keep you posted."
