I added divers dream transom zinc using half inch diameter silicon bronze studs. I found leftover roll of #6 marine grade (tinned) pvc wire. I can run two staight lines from engines to stud. On my tiara I have a few large clusters of green #8 bonding wires on strut mount as well as on engines. Thinking may from engine to strut, then to DD stud. Will I impeed the ground much to have the splice? I'm using the full metal lugs and heat em with tourch and soider em up. Connector are not copper though? What you think best?
