Bent shaft
valor21
"Blew up my lower unit last su
"Blew up my lower unit last summer on 1987 48hp evinrude,rebuilt it with new gear set and seals,after i got it back together i noticed the upper shaft was a little bent,how much can this shaft be bent and still be ok,need advice from the experts, thanks ps haven`t run it yet"
"basically,any bent shaft,is n
"basically,any bent shaft,is not good,....if u can see,the bend,its too much!..my question isss,...how,did u bend,the d-shaft,..and the prop shaft,musta been bad,baaad..."
"Ground up forward and pinion
"Ground up forward and pinion gears, don`t know why, and not sure why the shaft is bent"
