Bent prop shaft
big_red_friend
I just got a 1978 115 hp mercu
I just got a 1978 115 hp mercury. When I spin the prop by hand it spins in an egg shape instead of a smooth circle. Is my prop shaft bent or bad bearings? Help! I am new to boat motors!
If you don't hear any grow
If you don't hear any growling from the bearings as you spin the shaft...its a bent shaft. Someone hit something hard...more than likely with a stainless prop.
Two things it could be
(1
(1) the prop bush is off center
(2) the prop shaft is bent
Take the prop off and rotate the shaft and see if the shaft is wobbeling.
Use a piece of wire as your in
Use a piece of wire as your indicator. Clamp it to the cav plate with Vise Grips and aim the end of the wire at the center of the prop shaft.
Good luck!
Jeff
Thanx for your input I will be
Thanx for your input I will be tearing into it this weekend. Fishing opener is coming TOO QUICK!!! This is the best boating web site i've found!
