Bennett trim tabs simulator
el_pescador
Silver Medal Contributor
"It can be downloaded from her
"It can be downloaded from here.
http://www.bennetttrimtabs.com/simulator.htm
In addition of doing some "virtual boating" without using any real fuel or blowing your engine
, I find interesting to use the simulator to see how a boat reacts depending on the trim tabs adjustment."
"this is very interesting beca
"this is very interesting because this is exactly what my boat has been doing,Although It has no trouble getting up on Plane it does do the Listing thing to one side and it really doesn't matter if there is an uneven load or any passengers at all, when it decides to do it it just does it, I had almost rulled in favor of a swift under tow broadside the lower foot as I am in travel causing this leaning to one side
( listing)the lower unit on my boat extends almost 2ft. bellow the vessel this is the theory I had,
El Pescador you have advised me to get some Bennett trim tabs, But I have not done so yet, I think this will be an off season project,
Great Information...
"Can someone tell me the angle
"Can someone tell me the angle a trim tab gets to in relation to the ralative water flow before the water becomes turbulant under the trim tab . I believe bigger tabs and less angle is the way to go for effect and efficiency . Is there someone that KNOWS there stuff that can let me know some facts . Thank you ,Tod ."
