bendix gear on Johnson 88 spl won't engage fly wheel
Andrewkup
Hello, I just got the boat out to get her ready for spring. When i went to start the bendix gear won't go all the way up and engage the fly wheel. the starter spins and the gear turns just not all the way. I an able to manually turn the gear to get the teeth to engage and then it will start no problem. The battery is fully charged and clean terminals. thanks Andrew
Remove the ground stud on the engine and clean the threads. Check voltage at starter when engaged, should not drop below 11 volts.
The starter may need brushes replaced and the commutator cleaned and undercut. Mark the case and endcaps before disassembly. An old solenoid can also reduce the voltage/current to a starter w/worn brushes.
