Bellows for aq 130270
bussfuss
"where can i find exhust and d
"where can i find exhust and drive shaft bellows for a aq130/270. i cant find any. maybe i look in the wrong places? the drive shaft(u-joint) has been exposed to water, and leaking oil from that bellow where it is ripped ( on water and on land). oil leak not from engine. but oil level fluctuates in 270drive. how far do i need to go into the 270leg to fix it (maybe a seal)? i get water leaking from bellhouseing (cause of a bad bellow?). just looking for parts and tips before i start"
"Exhaust bellows:
[url=""]h
"Exhaust bellows:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-2758&returntopage= 80240797.htm
Drive bellows:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-2744&returntopage= 80240797.htm
It seems that your bellhousing bearing and u-joints have been exposed to water and you will have to change them. Unfortunately, to replace the primary shaft bearing inside the bellhousing you will have to pull the engine with the bellhousing. Also, you will have to renew the lip seal in the upper gear unit (part 16 in link)
http://www.dougrussell.com/partscatalog/volvo_omc/index.cfm?fuseaction=comp&grou p=3462&GroupList=3432,3433,3434,3435,3436,3437,3438,3439,3440,3441,3442,3443,344 4,3445,3446,3448,3447,3449,3450,3451,3452,3453,3454,3455,3456,3457,3458,3459,346 0,3461,3462,3463
I think you have an interesting job ahead."
"Wow El Pescador! Those are re
"Wow El Pescador! Those are really good prices. Doug Russell Marine wants $52.00 each. I got mine on Ebay for $84.00 together, plus shipping. I will have to remember for next time...."
