"Short story, I had a drive be
"Short story, I had a drive bellows fail, had to pull the engine and rebuild the intermediate shaft bearing and seals.
When I put the engine and housing back into the transom shield, should I use any type of sealant on the two large O-rings?
When I cleaned everything up, the last person that installed engine and clamping ring seemed to use the aviation brownish gasket sealant.
I also have read in here that some people use sealant on the bellows, what do you use? I've always just installed them dry.
Steve"
Steve"
