Hi all
Just finished up putting new oil seals on my prop shaft and a few other things. I'm installing the prop shaft and housing back into the lower unit and want to make sure that I don't damage the front/reverse and pinion gear's. I tested the forward and reverse gears by spinning the prop shaft and it sounds okay. The one thing I am unsure of is whether or not in reverse if the prop should spin in one direction freely or should it not move from left to right by hand.
Regards, Dan
Regards, Dan
