eastcoastitalian
i know there was a very long post on here somewhere about timing belts but i can't seem to find it again?? anyway i'm thinking the previous owner of my boat replaced the timing belt at some point and put it on wrong? the boat runs absolutly horrible when timed at 10 degrees btdc as the manual calls for at 750 rpm. but it seems to run almost perfect when it is set at 35 degrees btdc at 750 to 800 rpm which is almost what the degree should be for the advance at 2800 to 3700 rpm how would i go about making sure this belt was installed properly as i'm assuming it probably was'nt by the many other rigged up items i've found on the boat, thanks
