alaska_av8r
"1986 29 ft Cruisers with twin
"1986 29 ft Cruisers with twin Crusader 270's
After weeks of reading books and researching forums I have determined that the previous owner has the isolater wired incorrectly.
I am planning on rewiring the batteries and trying to design a more efficient system without costing an arm and a leg.
Here are my goals...
1. Simplify operation to one switch
2. Get the most out of the alternators
3. Get rid of the isolator.
From what I have gathered you cannot parallel the alternator outputs, not sure if would gain anything by doing this or not...from what I was told if I paralled them to charge a battery bank, one would see the others voltage and then reduce its own output thereby defeating the purpose.
Does this sound reasonable? If so how do dual alternator battery isolators get around this? With the diodes?
I have also read that it is better to set up the alternator to charge similar batteries (i.e start to start or deep cycle to deep cycle).
The alternators that I have are 8MR Motorola's with built in voltage regulation, they also do not have a separate "Sense" wire. Therefore this has lead me to do away with the isolator due to the voltage drop and no easy way around it.
The system I am planning will have one battery selector (which will determine which start battery will be used to crank either engine). Normally kept in position 1 unless that battery goes bad (minimal switching).
The port engine alternator will charge start battery 1 and thru an ACR charge start battery 2.
The starboard engine alternator will charge the house bank of deep cycles that are wired in parallel.
This keeps battery types to separate alternators and since the alternators are not wired thru switches no chance of open circuiting them.
The battery charger will feed start battery 1 with one lead and thru ACR feed start battery 2. The remaining two leads will go on the house bank.
you can see the diagram here http://www.hellzhoundz.net/crusadernewelect.pdf
Please feel free to make any suggestions keeping in mind I want to try to stay with one battery switch and make the system as versatile as I can in that situation. If it would be of any benefit I would still like to find a way to utilize both alternators to charge the house batts but don't even know if there is a benefit in that."
